Ive setup a camera with the background plate (houdini:backgroundimage) and used $F to sync it with the timeline, it works fine. then Ive cache the camera for a certain frame range into an usd file, and re-imported in a sublayer node. If I try to look through the camera the backplate is there but when I scroll the timeline the backplate in the viewport do not update, it seems it is doing a lazy evaluation of the node, just when I change a time parameter of the sublayer or I change a display option of the view-port the image gets updated. is it a way to force to update the sublayer if the time has changed, so it can read the current timestamp?
Cheers
R.
sublayer graph evaluation
1023 3 1- Ruspa
- 30 posts
- robp_sidefx
- 453 posts
- Ruspa
- 30 posts
- robp_sidefx
- 453 posts
