Access to hou.ParmTemplate.conditionals() result
1655
2
1
romawind
May 24, 2022 7:33 p.m.
Hello.
I am trying to modify the conditionals of the asset's parameters via Python.
The
.conditionals()
method returns a weird dictionary (set?).
How should I access the value using the key in such case?
Edited by romawind - May 25, 2022 11:37:54
romawind
May 25, 2022 11:45 a.m.
Actually I've already found a solution. :S
Simple
for x , y in conditionals_dict . items ():
key = str ( x ) # to compare with something like 'parmCondType.DisableWhen'
value = y
works fine.
Hope this will be useful for someone someday.
tamte
May 27, 2022 12:33 a.m.
its a normal dictionary, just keys are not string, but instances of hou.EnumValue
so to get the value of you should do:
print ( clr_type . conditionals ()[ hou . parmCondType . DisableWhen ])
print ( clr_type . conditionals ()[ hou . parmCondType . HideWhen ])
Edited by tamte - May 27, 2022 00:34:01
Tomas Slancik FX Supervisor Method Studios, NY
