Pivot Point Question
1003 3 1- eveying
- 19 posts
- tamte
- 8583 posts
- you can use Extract Centroid SOP, it really depends on what you consider a pivot
- there is also Extract Transform SOP if you want orient and scale also
- or if your geo is packed there is packedfulltransform and pivot intrinsic you can use to compute transform attribs and then delete prim to be left with the points
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- eveying
- 19 posts
tamteThanks, however when I tried to use Extract Centroid SOP, it create several points and no points is on pivot center. If I import a model from file node, is there any way to get the povit point like in transform node? Thanks!
- eikonoklastes
- 333 posts
