Transforming points via "Height" attribute:
   2024   2   0
I'm still starting out in Houdini and have a question which I think should have a fairly simple solution, but I'm left scratching my head. Essentially as you can see I have created a point attribute called "height" which is just a value between 0-1 based on colour.
What I'm trying to achieve is to basically transform the Y position of all the points based on the height attribute values accordingly. I can only get as far as setting the transform of the points by a random "height" value, which causes all points to have the same transform value, which is not what I need.
any help would be greatly appreciated, hopefully there is a simple expression to do so?
Ryan
Edited by FullBoyle - June 7, 2022 06:05:05
You generally don't drive a transform node with attributes. Just use an AttributeWrangle and type vex code.
v@P.y += @height;
Edited by Enivob - June 7, 2022 07:40:22
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
That worked great thank you.
