.. are they supposed to give different result .. given the same seed?
I “translated” the following simple VEXpression (i love to call 'em this way!! eheh)
$TX+($VX*rand($F*$PT)))/20
into a VOPsop …
but I have slightly different result when I compare point positions….
VEX rand() and VOP random
8781 2 0- VisualCortexLab
- 509 posts
- mark
- 2593 posts
sum][one
into a VOPsop …
The VEX random() is different and only looks at the integer component of the seed (providing more platform-independent consistent results).
The hscript rand() function takes a floating point number as a seed and hashes this. However, from compiler to compiler or platform to platform, the results may (though not usually) be different.
VEX also has the hscript_rand() function which uses the exact same floating point hashing that the hscript() expression function uses. It should provide the same results.
- VisualCortexLab
- 509 posts
Thanks a lot for your explanation
now it makes sense.
now it makes sense.
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
