Hi everyone,
so i want to create a vector attribute that has xyz where xz are static floats and y is the actual y position.
I would have thought putting it as such :
v@centerpos = (0, @P.y, 0)
but when I do so all it does is full the xyz with the z value in the geometry spreadsheet and I cant figure out why NOR how to solve it... anyone can tell me what I'm missing ?
ie : if i put (0, @P.y, 1) i get : 1 everywhere and if i put (0.0.@P.y) i get P.y on all three fields (xyz).
Creating vector with attributes ? Help needed logical problm
1134 1 0-
- Lucasdooka
- 2 posts
- jsmack
- 8252 posts
Lucasdooka
Hi everyone,
I'm not sure how you're not getting a syntax error. () is for grouping arithmetic operations or for function calls.
To create a vector from variable arguments, the set() function is needed. call set(a, b, c) to create the vector {a, b, c}
