Hi! I'm looking for informations on how to do nested HDA in unreal when working inside a studio.
I'm developping a tool for other artists and for practicality I started using HDA inside my tools. When used on another computer the tool doesn't work. I have found the problem to be those HDA missing. I initially fought they would be embedded.
So, as a simplified example, we have TestingGrid_HDA_A referencing TestingGrid_HDA_B
How can I provide HDA B to my coworker and have a correct reference inside HDA A.
Nested assets in a studio
1138 1 1- CorentinB
- 2 posts
- CorentinB
- 2 posts
Ok I fixed my issue and it was simple.
So my issue was how to have HDA A finding HDA B on another computer inside unreal.
My solution was this. (We are using perforce to share the source files of the project.)
So I will have a folder containing all of my "subHDA" and every tool I create will search this folder if needed.
Otl search path can contain multiple folder if needed. (separated by ; )
There is also the possibility to create en houdini.env for unreal but Otl search path is enough for us.
- I submit HDA B in perforce. (exemple : F:\Source\HoudiniTools\HDA\HDA_B.hda)
- In Unreal > Houdini plugin settings > Otl search path > link to the folder. (F:\Source\HoudiniTools\HDA\)
- Colleagues do the same with their own path.
- Envoy!!
