Hello, everybody!
I was working on the personal project and wanted to implement Karma render in it. But I haven't found how to use aces color space in Karma.
Does Karma even support the aces or it is just linear?
If it does not, when will it come?
Thank you!
Karma ACES
1544 1 3- Daniel Mille
- 3 posts
- jsmack
- 7801 posts
What are you rendering? Karma doesn't really have any spectral effects where the colorspace has to be implemented with the renderer on more than a semantic level. View the renders with an ACES transform and use textures in ACES space, and you're rendering in ACES. The only area that's definitely not ACES compliant is the hair shader melanin absorption coefficients, which are hard coded to sRGB.
