Hi Magicians,
I want to run a cloth simulation where I transfer Cd onto my base cloth geo with a moving object.
The Cd attribute will affect the restlenght. Now it works good but only for the first frame.
Does the vellum solver only take the first frame before it goes to simulate that?
Is there a wway I tell the solver to take the to be solved object and check it each frame?
I've attached the ptoject. Any help is welcome, thanks in advance!
Solving updating geometry in Vellum solver
1535 1 1- Smicksus
- 5 posts
- HM_2020
- 43 posts
try this method - https://youtu.be/qAraO2E-v84?t=1314 [youtu.be]
or look into Sop Solvers and Constraint Properties node to change things over time.
