Rotating in cop filter.
3119 10 2-
- NicTanghe
- 244 posts
Hello I`m trying to make a flakes normal map.
For this i need gradients applied with a random orientation on preferably the id of the cell noise node.
all of the rotation / transformation nodes dont seem to have an input for the thing that needs rotation.
This confuzes me.
Also i cant seem to find a node that allows you to reapply XY. the texture node could do thtat but it only works on images.
This confuzes me.
Edited by NicTanghe - Nov. 7, 2022 11:47:24
- jsmack
- 8183 posts
- NicTanghe
- 244 posts
- animatrix_
- 5125 posts
You can't change the positions of the pixels just like you can't change the position of voxels in volumes. You have to change the look up positions.
Here is how to apply swirl to an input image in COPs for example (Bilinear filtering in this example):
float mirror ( float p ) { return abs ( p - 2.0f * floor ( ( p + 1.0f ) / 2.0f ) ); } vector [ ] computeSamplePoints ( int quality; int xres; int yres ) { vector samples [ ]; int nsamples = quality; int tsamples = nsamples * nsamples; float n = 1.0f / ( 1.0f + tsamples ); for ( int i = 1; i <= tsamples; ++i ) { float y = i * n; float x = frac ( y * nsamples ); samples [ i - 1 ] = set ( ( x - 0.5f ) / xres, ( y - 0.5f ) / yres, 0 ); } return samples; } cop2 swirl ( float angle = 0; float r = 1; vector2 t = { 0.5, 0.5 }; int quality = 3; int filter = 1; int outside = 0 ) { float rx = 0.5 * r; float ry = 0.5 * r; float maxr = rx; float x = X - t.x; float y = Y - t.y; float sx = max ( 1, 1.0f * XRES / YRES ); float sy = max ( 1, 1.0f * YRES / XRES ); if ( XRES > YRES ) rx = 0.5 * r * min ( XRES, YRES ) / max ( XRES, YRES ); else ry = 0.5 * r * min ( XRES, YRES ) / max ( XRES, YRES ); int setSample = 0; vector sample = 0; vector samplePoints [ ] = computeSamplePoints ( quality, XRES, YRES ); foreach ( vector p; samplePoints ) { if ( ( x * x ) / ( rx * rx ) + ( y * y ) / ( ry * ry ) <= 1 ) { float xx = x * sx + p.x; float yy = y * sy + p.y; float amount = ( maxr - sqrt ( x * x * sx * sx + y * y * sy * sy ) ) / maxr; float theta = amount * amount * radians ( angle ); float s = sin ( theta ); float c = cos ( theta ); xx = c * x - s * y + t.x; yy = s * x + c * y + t.y; if ( outside == 0 ) { xx = mirror ( xx ); yy = mirror ( yy ); } if ( filter == 0 ) sample += cinput ( 0, PL, AI, xx % 1, yy % 1, F, "wrap", "streak" ); else if ( filter == 1 ) sample += binput ( 0, PL, AI, xx % 1, yy % 1, F, "wrap", "streak" ); else if ( filter == 2 ) sample += finput ( 0, PL, AI, xx % 1, yy % 1, F, "wrap", "streak" ); setSample = 1; } } if ( setSample ) assign ( Cr, Cg, Cb, sample / arraylength ( samplePoints ) ); }
- NicTanghe
- 244 posts
thx !
I’m having some problems logically deconstructing the code, though.
1. the computeSamplePoints definitions throws me the error,
I don't understand why I would get this error
So I can't get the code working.
2. I don't understand what the samples actually are. I would think, based on language, it's just taking every so many pixels instead of all of them.
3. the cop2 type is confusing to me and i also didn’t find any documentation on it
4. it's not really used in your code, but I can never figure out how to use inputs and outputs in the snippet node
Any further help is greatly appreciated.
Syntax error, unexpected identifier, expecting ';'. (7,12)
Edited by NicTanghe - Nov. 8, 2022 13:59:45
- animatrix_
- 5125 posts
That function is for generating multiple sampling positions for supersampling:
https://en.wikipedia.org/wiki/Supersampling [en.wikipedia.org]
Sorry this code is not meant to be put inside a Snippet VOP. It's created using File -> New Asset -> VEX (COP).
I attached the HDA itself because it has HDA level parameters also. Some default COPs are created this way, i.e. Velocity Blur COP. You can tell this if the HDA has a button called Edit VEX Function.
- jsmack
- 8183 posts
NicTanghe
thx !
1. the computeSamplePoints definitions throws me the error,Syntax error, unexpected identifier, expecting ';'. (7,12)
I thought you were making a normal map. Why do you want to displace the texture space?
- NicTanghe
- 244 posts
- tamte
- 9416 posts
- NicTanghe
- 244 posts
- mestela
- 1857 posts
I've been playing with similar ideas, made a simple setup that might help.
https://www.tokeru.com/cgwiki/index.php?title=HoudiniCops#Cellnoise_with_rotated_gradients [www.tokeru.com]
