Single layer exr's
5043 9 1-
- sniegockiszymon
- 71 posts
- ysysimon
- 75 posts
- sniegockiszymon
- 71 posts
- jsmack
- 8192 posts
- sniegockiszymon
- 71 posts
jsmackYes,I want all passes on seperate file, it should be one checkbox like in redshift or blender for example. Multi layers are not always efficient esspecialy when you are using subtractive workflow in compositing
legacy exrs still have multiple layers. The new exr is 'multi-part' which some older software doesn't support. Are you looking for one layer per file? In that case you'll have to create a product for each layer with a unique file name.
- ysysimon
- 75 posts
sniegockiszymonjsmackYes,I want all passes on seperate file, it should be one checkbox like in redshift or blender for example. Multi layers are not always efficient esspecialy when you are using subtractive workflow in compositing
I thought this approach would increase a lot of hard disk IO time?
- sniegockiszymon
- 71 posts
ysysimonYou are still saving the same amount of data, but in multiple files, so propably saving lasts a little bit longer, but there is huge advatange in reading when you are using subtractive workflow in compo (you load only beauty and then subtract only pass you want to change). There is great explanation https://www.youtube.com/watch?v=e79yb3UvQTQ [www.youtube.com]sniegockiszymonjsmackYes,I want all passes on seperate file, it should be one checkbox like in redshift or blender for example. Multi layers are not always efficient esspecialy when you are using subtractive workflow in compositing
Edited by sniegockiszymon - Nov. 22, 2022 17:34:20
- jsmack
- 8192 posts
sniegockiszymonysysimonYou are still saving the same amount of data, but in multiple files, so propably saving lasts a little bit longer, but there is huge advatange in reading when you are using subtractive workflow in compo (you load only beauty and then subtract only pass you want to change). There is great explanation https://www.youtube.com/watch?v=e79yb3UvQTQ [www.youtube.com]sniegockiszymonjsmackYes,I want all passes on seperate file, it should be one checkbox like in redshift or blender for example. Multi layers are not always efficient esspecialy when you are using subtractive workflow in compositing
Multipart exr already only loads the passes being used.
- BryanRay
- 46 posts
- ivan.salmeron
- 4 posts
