Vex: reverse points in a line
   749   2   0
In vex, I want to reverse a 2-pt line so its points switch their order (like Sort->Points->Reverse), but I can't get it to work. I tried rewiring the vertices on the existing prim, but the prim still retains its order;
int primPts[]=primpoints(0,origPrimID);
setvertexpoint(0,origPrimID,0,primPts[1]);
setvertexpoint(0,origPrimID,1,primPts[0]);
I tried creating a new prim with points in my preferred order and removing the old prim, but I still see the "wrong" point order.
newPrim=addprim(0,"polyline",primPts[1],primPts[0]);
removeprim(0,origPrimID,1);
Edited by element33 - Jan. 18, 2023 03:42:13
Why?
It would be incredibly inefficient to try to do that in VEX
In your code all you are doing is just rewiring vertices or recreating new ones and attaching to the same 2 points
If you want to reorder points you would need to also swap all their attributes including P
FX Supervisor
Method Studios, NY
Found the issue: the line shared points with other prims. I had to "break out" the line by creating copied new points (which can't be fused or they'll snap back to the orig. order).
int newPt0=addpoint(0,primPts[1]);
int newPt1=addpoint(0,primPts[0]);
pr=addprim(0,"polyline",newPt0,newPt1);
removeprim(0,origPrimID,0);
