Aight so the title says everything, when I move the "min wavelenght" channel of the ocean spectrum, nothing happens.. I hant bigger waves with no details so I can add it with another spectrum later..
There is no error message at all so I'm pretty confused..
Ocean Spectrum Minimum wavelenght does nothing..
969 2 0- Hugo Samson
- 4 posts
- tamte
- 8622 posts
- tamte
- 8622 posts
Hugo Samsonto answer the actual question, seems like that slider works only in Phillips spectrum type not with the new default TMA, maybe submit a bug, since it's either an oversight and it should work or at least should be disabled in that mode if it is not meant to do anything
, nothing happens
but the filters should get you close to what you want in either mode
Edited by tamte - Jan. 27, 2023 21:38:58
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
