The main problem is that you're trying to modify unpacked instances. The secondary problem is that you can't edit bellow instance roots. I recommend using the pattern selector to see if your selection patterns are valid
Hi thank you for the quick response, much better than the extract instances solve I finally got working and was crashing previously in a full scene. Yes on the pattern editor, will use that lots now.
