Hello, I am a noob in vex. I was stuck with how to create a 9flt(matrix), not 9flt in a wrangle node.
And how to access this 9flt(matrix) data, I've tried the getcomp(), but not work.
what's the different between 9flt and 9flt(matrix)?
569 2 1- ZiheX
- 2 posts
- Tanto
- 393 posts
You can add the type info using setattribtypeinfo(). You can then access values with getcomp() using a row and column index. So for example, in a detail attribute:
3@myMatrix = ident(); setattribtypeinfo(0, 'detail', 'myMatrix', 'matrix'); f@value = getcomp(@myMatrix, 1, 1);
Edited by Tanto - Feb. 14, 2023 14:38:26
- jsmack
- 7770 posts
