How to see why a TOP node failed
   2315   2   0
Hi! I'm pretty new to TOPs and I've been following this super awesome tutorial [www.sidefx.com] series on it. When I got to the chunk on the ImageMagick node, every time I run it, I see that the work items failed but I don't know why.
As far as I can tell, ImageMagick has been properly installed.
Is there any way I can get the error message to see why this is failing?
Anson
Edited by AnsonSavage - March 30, 2023 18:25:40
there's 2 levels of loging, the node level, which will tell you errors from the high level orchestration/schedular side, and per workitem eerrors.
Try double clickiing on a red dot, in the dialog that pops up you should be able to see whats going on when imagmagick is called.
mestela
Double clicking the red dots showed me the message, thanks so much!!
Anson
