How to read custom variable in node?
1034 4 0- HenDaSheng
- 60 posts
- graham
- 1907 posts
Since you're creating the attribute in VEX you need to manually create a mapping between the parameter and a variable:
That being said, PolyExtrude won't accept a local variable in that parameter so even if your variable was correctly set up it would throw a warning. In your case you could do something like set the Distance to 1 and use your attribute as the Distance Scale in the Local Attributes tab.
addvariablename(0, "h", "MYVAR");
- HenDaSheng
- 60 posts
graham
Since you're creating the attribute in VEX you need to manually create a mapping between the parameter and a variable:addvariablename(0, "h", "MYVAR");
Thank you for your help, but I don't understand the specific method, can you be more specific?
- BabaJ
- 2041 posts
- HenDaSheng
- 60 posts
