Karma - Turn Off Self Shadowing On Particular Objects
   10198   4   1
I have a large, noisy shaped ground plane that includes lumps, walls etc. all in one combined mesh.
I'd like to receive shadows on this object, but not cast or catch shadows from itself. Is this possible with light path expressions, or render geometry settings?
Setting its render visibility to primary will mean it won't cast shadows, but will still receive shadows.
Or -shadow also works if you want it visible in indirect See render visibility here: https://www.sidefx.com/docs/houdini/props/karma.html [www.sidefx.com]
Edited by protean - June 21, 2023 07:55:15
john @ goodbyekansas
mestela
Right! So it does. I was getting very mixed up, as I had already tried this, but what I was actually seeing was shadowing from an overall very soft dome light. I assumed this was shadowing coming from the ground object itself.
Thanks for clearing this up for me!
protean
This is also a super handy page of info, not just for the shadow tips. Cheers!
Edited by GlennimusPrime - June 22, 2023 02:30:01
mestela
that's not the same as turning off self shadowing though, since such object will not cast shadows to any object and will also not appear in any of the secondary rays
protean
this is closer, but it will still not cast shadows on any other objects
so it would still be handy to be able to turn off self shadowing only, but still cast shadows to other objects and appear in other secondary
or for that matter to be invisible to any specific secondary self hit
I guess what would need tracesets to be able to exclude self
Edited by tamte - June 27, 2023 01:14:00
