Polysplit issues
   570   0   1
Does anyone know how use multiple Opps like Polysplit, and not having to redo all of them when adjusting the first one because the point count has changed ?
It looks as if Polysplit uses "Split Locations" and not point numbers which should prevent this behavior, but no matter what I try, Polysplits break most of the time when I make an adjustment to the first one, disable, or delete it, and I have to redo a lot of work several times.
Very frustrating.
One would expect the point of a procedural workflow is to be able to make adjustments, and downstream all is automagically updated, right ?
Maybe there's an alternative that actually is procedural ?
Also, is there a way to continue a Polysplit later on ?
Thanks.
