Hey guys, I have a problem with karma. Could you please help
716
2
1
hfsxddut
Sept. 4, 2023 11:54 p.m.
I want to render a bonfire with Karma.But when I got everything done in the "stage", this error showed up as I click "save to disk".What should I do? I do have a camera...
Thank you in advance!
Heileif
Sept. 5, 2023 7:34 p.m.
You need to select the camera you want to be used for rendering in the Render settings(karmarendersettings). Its at the top of the settings. You should also probably connect your camera to the "Input Stage" input and not the "Additional Render Vars"
Edited by Heileif - Sept. 5, 2023 19:34:59
hfsxddut
Dec. 4, 2023 1:28 a.m.
Heileif You need to select the camera you want to be used for rendering in the Render settings(karmarendersettings). Its at the top of the settings. You should also probably connect your camera to the "Input Stage" input and not the "Additional Render Vars"Thank you, problem resolve ed!
