Geometry unpacked from folder isn't writable? Why?
   1278   2   1
For example, this Python SOP (assuming Base.skel exists):
geo = node.geometry()
skel = geo.unpackFromFolder("/Base.skel")
skel.addAttrib(hou.attribType.Global, "frame_range", (1, 1))
skel.setGlobalAttribValue("frame_range", (1,120))
results in:
hou.GeometryPermissionError: Geometry is read-only.
It's a bit weird tho... geoitself is writable, why isn't the geometry unpacked from it? What's the correct way to handle it? Just create a new hou.Geometry()then copy()?
Edited by kodra - Dec. 23, 2023 02:29:14
try doing this:
skel = geo.unpackFromFolder("/Base.skel").freeze()
Just to explain, the geometry objects returned by unpackFromFolder() can be a reference to the geometry directly inside the packed primitive for efficiency reasons. So doing "freeze()" gives you a writable copy of the geometry.
