Hello there, I'm coming from Maya and trying to get used to Apex by creating a simple gear rig with some different ratios. For testing-purposes, I'm using a stash-node where I'm manually putting stuff together:
1. I set up 3 transform-joints for each gear
2. getting the driver-rotation by "exploding" the transform matrix
3. extracting the desired rotation axis -> multiplying it with the gear-ratio -> piping the value into a new transform that then connects to the point-transform
That works in general, but I'm facing pops on the driven rotation -> driven geo pops back every 180 degrees -> I guess this is due to
the fact that the internal rotation representation is radians right? It's a simple and maybe trivial question, but I can't find anything in the docs. Also is there a way to output values to the console or "watch" them in Geo-Spreadsheed-viewer?
Thank you very much!
[Apex Graph] transformobject-node issue with rotation
1589 3 0-
- Fraenk
- 24 posts
- kodra
- 373 posts
The simplest way is to get your rotation angle directly from promoted channels (the 'r' input of a TransformObject that connects to __parms__) instead of exploding the transform matrix.
Nothing to do with radians or degrees. It's about how transform matrix works. For example, if you tell it to rotate around x axis by 420 degrees, it will be like "okay so you mean 60 degrees right?" This "420 degrees" information can't be stored in a transform matrix.
APEX Invoke Graph with debug graph on. I've made a wrapper around it:
https://www.sidefx.com/forum/topic/93910/ [www.sidefx.com]
I guess this is due to the fact that the internal rotation representation is radians right?
Edited by kodra - Jan. 22, 2024 12:07:29
- Fraenk
- 24 posts
Thank you very much for the fast reply and after converting the rotation-outputs to radians -> multiplying with the gear-ratio and converting back from rad to deg all is fine. I could of course simply connect the xyz-rotation-channels directly, but when you gonna multiply it with a value you are facing those pops (at least I did). Anyway ... maybe I did something else wrong.
Your apex-anim-scene-debug wrapper sounds exactly what I was looking for. Thank you VERY much again, I'll test it out asap!
All the best!
All the best!
- william_harley
- 89 posts
Fraenkyour safest bet at the moment would be to use the parameters directly. you are getting the raw parameter data.
All the best!
here I have set up a basic gear system just using the parameters.
