Hi, I am trying to use crowd&ragdoll setup to flow agents by water. This time I can compleltly ignore agent status and start from ragdoll status.
When siming, I saw a body is bending very strange way, and I thoguht bonecapture biharmonic (bind skin) was wrong. However, I compared those constraint icons between SOP level viewport and DOP level viewport, and noticed that some of constraints configure wrong angles/direction. ALso I confirmed my skelton seems to be fine, too.
I guess the agent configure joints SOP produces a bad constraints network because this node is located just before feeding to dopnet.
Please let me know if you have a same problem and how to fix them, thanks!
agent configure joints SOP is not working for crowd ragdoll
265 0 2- masa90210
- 16 posts
