VEX - testing attributes within a group of attributes
   386   3   2
I have some primitives that have an attribute "class" and I would like to assign an attribute "@unique=1" to each primitives that only have the same value for "class2" for the same value of "class".
--> if there's only the same value for "class2" for all the primitives with the same "class" value then assign to all of this primitives the attribute "unique" with a value of 1 and if there's more than one unique value, give them a value of 0
I tried to promote the "class" attibute to groups but I didn't manage to run the test for each group
Any help/guidance would be super welcome, thank you!
You could do a "for each named primitive" loop using class, and assign @unique=1 when the length of uniquevals(0, 'prim', 'class2') is 1.
you can also use 2 attrib promotes to get min and max of "class2" from prim to prim using "class" as piece attrib
then do prim Wrangle:
i@unique = i@min == i@max;
Edited by tamte - Feb. 20, 2024 16:47:09
FX Supervisor
Method Studios, NY
Thank you very much, it worked perfectly!
