All image processing, or 2d volume setups i have seen use native houdini volumes and the collated rank like C.r C.g C.b for working with colors. I have heard mentions of using vdbs for the same processes, but have not come across any comparisons or examples.
Assuming the target language is OpenCL is there any benefit to using vdb over volumes? Might there be when using vex? Currently i have tried to use openCL with the new vector volumes but am unable to bind them.
Volume or VDB for image processing with OpenCL?
279 2 0- Latimerias
- 19 posts
- animatrix_
- 4516 posts
For images you don't need sparse volumes so regular dense volumes are better suited.
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
- Latimerias
- 19 posts
animatrix_
Would this change if im doing texture generation and potentially a large portion of the texture is "empty"? I read when using openCL and VDBs it only reads/writes over active voxels whereas I assume volume wrangles/vex do not have this same functionality?
Edited by Latimerias - April 14, 2024 00:48:05
