Hi everybody.
Well, I am trying to create a sequence of IFD files from a Mantra ROP, like in H8 to render using Mantra but checking the Disk File option and setting the file path seems to not work.
Instead the ROP renders its outoput and not create the ifd files.
I am missing something about creating ifd files with H9?
Using H9.0.725 win64.
Thanks.
Creating IFD files from H9
3945 3 1- lisux
- 581 posts
- mark
- 2592 posts
lisux
Hi everybody.
Thanks.
If you render from the viewport, it will always render through a command.
If you are running apprentice, you can no longer generate IFDs on disk (though I don't think you could before).
I believe that if you use the Render menu, you should also be able to generate IFDs on disk.
- lisux
- 581 posts
- mhenrie
- 11 posts
