Use construction plane handle outside of viewport state?
   1546   5   1
Even when I have c-plane and c-plane handle displayed, the handle is greyed out:
Only if I have a viewport state activated, the c-plane handle is available:
Is this... really by design? It doesn't make a lot of sense to me, as the construction plane doesn't "belongs to" any viewport state.
Screenshot 2025-02-19 052327.jpg (170.5 KB)
Screenshot 2025-02-19 052340.jpg (228.6 KB)
Well, perhaps the construction plane 'belongs' to the construction plane state : )
Personally I don't use the CP handle option available in the CP menu, I just toggle in / out of it with the forward slash key "/" - that puts you in construction plane state with the handle being active.
If it was permanently active it how would you, say move a point on an object if the construction plane was centred on that point?
Edited by Mike_A - May 23, 2025 18:32:12
raincole
It's only greyed out if the selection tool is active. It becomes active if Move, Rotate, Scale or, like you already said, Show Handle (viewport state) are active. I didn't experiment with the Pose.
My guess is that it's like that by design. I've never thought about it much, because I've never perceived it as a problem. It's just how it works, so I guess it's best to accept it as it is.
Edited by ajz3d - May 23, 2025 20:55:10
The main problem with c-plane in my opinion is the unavailability of the "tangent plane snapping" function, which is available for a regular plane. And instead of logically using a temporary c-plane, you have to create a real plane, position it, and snap to it. Which is longer, more inconvenient, and is a function for c-plane, in fact. This is a strange situation.
The lack of "Align Handle" submenu in C-Plane context menu is a problem too. What's the point of a C-Plane if I can't align it with selected primitives? Up vector should also be exposed for adjustment one way or the other. Just saying.
Also, my another wish is that if C-Plane is enabled, viewport snapping (to front/left/up/bottom/right/back) respect C-Plane's orientation. Or maybe it's already possible to accomplish that, but I'm not aware of it...?
ajz3d
Agreed 100% on this - I believe I filed an RFE for this a few years ago...
The only single view that does respect CP orientation, as far as I know, is dropping down the 'Perpective' menu > 'Home' > 'Construction plane normal'.
ajz3d
You've got quite a flexible 'Align state' - semi-colon - that can be used with the CP.
But I do agree that Sidefx could make CP usage much better. It's an important tool in my book.
Edited by Mike_A - May 29, 2025 18:01:57
