Hi everyone,
I am trying to cook a houdini node with python script, by getting a node “end_node” with hou.node(“../path/to/that/node”), and then use end_node.cook(force=True) to get it to cook. To test it, there is a file saving node before the end_node, so if it runs successfully, the script will save a file.
This works well with geo network. However, when I tried to implement this in TOP network, the python could get the end_node, print the name of that node, but it does not save a file. I am using a ROP Geometry Output node as the end_node.
Does hou.node().cook() work with TOP network? If it does, how should I organize the script?
Many thanks!
Using hou.node().cook(force=True) on TOP nodes
10590 2 1-
- lzl
- 7 posts
- X_H_N
- 31 posts
- lzl
- 7 posts
X_H_N
https://www.sidefx.com/forum/topic/68141/?page=1#post-289575 [www.sidefx.com]
Thank you so much! It solved the problem
For anyone looking at this thread in the future, here is what I did –
Initially when the code works in SOP, it was
node = hou.node(node_path)
Now for the TOP version, it is
node.executeGraph(False, True, False, False)
Basically the TOP graph needs to be cooked, so the PDG graph would exist and could be executed.
Edited by lzl - 2019年8月19日 00:11:45
