Hey!
I use the GameDev Maps Baker in an HDA to generate normal maps for a cloth simulation.
The HDA is used in Unreal Engine to generate sheets covering various objects.
So…now I'd like to bake a normal map for the sheet to use in a material.
The normal maps need to baked once the sheet is finished simulating in UE4. Therefore I tried to expose the “Bake” button
from the Maps Baker, but I get the error "the selected subnet has references to nodes outside the subnet…etc".
Screenshot attached.
Is there a way to make this work (maybe through a fix?)
Since we're already generating assets inside the game engine it would be supercool to generate the maps from there as well!
Best regards,
Ron
Expose GameDevMapsBaker "Bake" button to game engines
4531 4 1-
- ron281279
- 36 posts
- Ambrosiussen
- 197 posts
- ron281279
- 36 posts
- ron281279
- 36 posts
Hey Paul!
I tried to add the MapsBaker to the editable nodes but this doesn't seem to work.
Unreal throws an error when re-importing my HDA (finished cooking with errors).
I also tried to add only the “switch1” node to editable, since that was the node that game the error in the first place. Still no luck. Same error.
Is there something i'm missing?
Thanks,
Ron
Thanks,
Ron
- Ambrosiussen
- 197 posts
Hi Ron,
Take a look at this tutorial. Simon covers how to do it for Unity, but Unreal should work with the same steps
https://www.sidefx.com/tutorials/sci-fi-crate-generator/ [www.sidefx.com]
(Part 3 covers baking)
