How do you make unique rocks so the noise doesn't repeat?
401 3 0-
- mixtureFeelings
- olivierth
- 1233 posts
If your noise is driven by the position, you could simply offset the geometry a different amount on X at every loop. Could be driven by the iteration.
To get the iteration value, make sure you have a Block Begin node set to Fetch Metadata.
...From there, I only know the wrangle method so, not sure how to get the iteration attribute inside the Point Vop. I think your need a bind node inside the point vop.
Edited by olivierth - 2026年8月17日 14:54:19
-Olivier
- 9727 posts
- Konstantin Magnus
- 744 posts
You can offset noise patterns on the same position with a VEXpression inside an attribute noise node so each copy takes on a different shape.
offset.x += float(i@copynum);
