I was wondering if there is a secret way to drag and drop files from the Network View into a LOP Network or Solaris Stage in Houdini 22 ?
Or does one still have to manually create a separate Sopimport for every single object , then set the path and merge it for each and every file ?
What if one needs to import 100 separate objects ??
Drag & drop Solaris ?
847 4 1-
- toonafish
- 620 posts
- Heileif
- 317 posts
No Houdini Infront of me now.
But you can probably drag drop all your objects into 1 Scene Import, Into the object selection?
This is if you don't care about the scene hierarchy.
For Each nodes and SOP Import with Iteration Method = For Each String in Parameter, could also work.
Edited by Heileif - 2026年8月17日 07:00:57
- toonafish
- 620 posts
yep , but how useful is that if you need separate objects , as in most of the time ?
And even then , you first have to create a "Sceneimport" node. How convenient would it be if one could simply drag and drop any node into any view and Houdini would automagically create the appropriate node.
I find it amazing that so many basic functionalities like this that would speed up the workflow so much , are still missing in an Application like Houdini.
I suspect if SideFX would design a car , the doors wouldn't open from the inside , because you can roll down the window and open them from the outside , so why bother adding a handle ;-)
- Mike_A
- 434 posts
- chrism
- 2664 posts
