Pragmatic VEX: Volume 1 [4K] [H20]
68268 79 5-
- animatrix_
- 5319 posts
Heightfield advection is a powerful technique in Houdini for simulating complex terrain evolution and fluid-like effects.
- animatrix_
- 5319 posts
Intrinsic UVs in Houdini are a powerful way to access geometric properties without extra attributes. Depending on the primitive type, they are interpreted differently.
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
Houdini Tokyo HIVE video is live:
Edited by remiz - 2025年11月13日 10:25:56
- animatrix_
- 5319 posts
I wanted to share a quick visual comparison between the SideFX recording of my Houdini HIVE Tokyo 2025 session “Adaptive Fracture Synthesis and Propagation in VEX using OpenSubdiv Limit Surface Derivatives” and my own local QHD capture.
The SideFX version is completely fine for watching the presentation, but my recording was captured directly from my display source with no compression loss, so it preserves a lot more clarity across the entire presentation. This includes all geometry details, colors, UI elements, and text. This is one of the main reasons I am preparing my own edited cuts.
The attached images show the difference between the two versions.
The full END-JPN cut will be posted next, followed later by the English-only version. These edited cuts will be available exclusively to paid members on Patreon [www.patreon.com].
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
- animatrix_
- 5319 posts
Pragmatic VEX: Volume 1: Canonical Version Update
Over the past 3 months, I’ve completely rebuilt the course.
Every video has been re-edited for better flow, pacing, and clarity.
Explanations have been refined, key sections restructured, and the overall learning experience has been significantly improved.
This is now the canonical version of the course.
It replaces the previous version.
• All lessons reworked for tighter structure and better comprehension
• Redesigned concept visuals and supporting material for clearer presentation
• New annotations to reinforce important ideas
• Help pages redesigned with proper styling instead of raw captures
• Updated to align with current Houdini workflows
The goal was to reduce friction and improve understanding while keeping the full technical depth intact.
If you already own the course, this update is available to you.
If you were considering it before, this is the right time to start.
More content is already in progress and will be released this year.
- alena.bejenarou
- animatrix_
- 5319 posts
alena.bejenarou
Hi Do you still have the free version available that was previously onside fx website? Thank you
Hi, yes it's on the SideFX page:
https://www.sidefx.com/tutorials/pragmatic-vex-volume-1-free-samples/ [www.sidefx.com]
But it doesn't include the latest major update released.
- animatrix_
- 5319 posts
Polar Inversion COP [www.patreon.com]
I have been experimenting with Houdini’s new Copernicus network and started porting some of my existing COP tools into custom OpenCL COP nodes.
The first one is a Polar Inversion filter implemented directly as an OpenCL COP node.
The core mapping is based on radial inversion around a center point:
scale = radius² / distance²
In practice, the important part is not the formula itself, but making it stable and usable as an image filter.
The implementation uses inverse mapping, where each output pixel traces back to the corresponding source position. Near the inversion center, the denominator is clamped using a pixel-footprint floor, with an optional softness floor. This avoids the unstable singularity you would otherwise get from dividing by a near-zero distance.
For sampling, the node uses deterministic subpixel supersampling and Houdini’s rectangular filtered sampling through "imageSampleRect". The filter footprint is currently based on the output pixel footprint, which gives better reconstruction than a naive point lookup while still remaining predictable and fast.
This is the direction I want to take with Copernicus: converting my existing COP nodes and implementing more advanced image filters, compositing operators, and procedural transformations that are not currently available in Houdini.
The goal is to build a deeper image-processing toolset inside Houdini, using the same philosophy I use in my VEX work: low-level control, practical performance, and tools designed around real production needs.
Edited by animatrix_ - 2026年6月1日 02:28:57
- animatrix_
- 5319 posts
Following up on my earlier COP filtering work, I added another high-quality method to OSSI (Output-Space Subpixel Integration) and compared it with the updated Houdini 22 Swirl COP.
H22 is a substantial improvement over H21 in terms of smoothing the swirl lines, but the central singular region is still visibly unstable and poorly resolved. Some broader curved regions also become noticeably softened. This is consistent with Box filtering over a rectangular area footprint estimated from finite differences of the warp, whereas OSSI integrates how the nonlinear deformation varies across the output pixel.
The new method uses adaptive antithetic Owen-scrambled Sobol sampling. Sobol provides low-discrepancy progressive coverage, Owen scrambling changes the sequence per pixel to reduce visible sampling structure, and pairing each offset with its opposite keeps every completed pair exactly centered.
Like my existing Adaptive R2 method, the sample count and integration width respond to the estimated warp difficulty. Adaptive R2 uses a lightweight progressive R2 disk sequence with a hashed per-pixel rotation, while the Owen-Sobol method uses pixel-specific scrambling of the Sobol sequence together with antithetic sample pairs.
The sample budget and integration width are driven by a conservative finite-difference Jacobian envelope and a footprint-scale second-order nonlinearity estimate. Power-of-two pair budgets evaluate the Sobol sequence at its strongest stratification points as sampling increases.
This is a comparison of the complete stock and custom implementations, not an isolated Box-versus-Sobol test, since their center regularization and footprint-planning strategies also differ.
- animatrix_
- 5319 posts
https://www.patreon.com/animatrix/posts/flow-of-swirl-166952784?pr=true [www.patreon.com]
Following up on my previous Swirl COP filtering tests, this update focuses on the deformation model itself: how multiple overlapping swirls are combined.
The Houdini 22 implementation processes its point-driven swirl maps sequentially. Each map receives the position produced by the previous map, giving an ordered composition:
p_out = F_n ∘ … ∘ F_1(p)
Because nonlinear maps do not generally commute, changing the point order can change the resulting deformation.
The custom implementation instead constructs a stationary velocity field by summing the contribution from every swirl at the same current position:
v(x) = Σ v_i(x)
The output position is the time-one flow of that combined field, obtained by solving:
dx/dt = v(x)
All swirl contributions therefore interact during integration rather than being applied as completed transforms one after another. Reordering the swirl points does not change the mathematical field, apart from floating-point accumulation differences.
The flow is solved primarily with adaptive Dormand–Prince 5(4), using an embedded error estimate to control the integration step size. Fixed-step RK4 remains available as a reference and as an explicitly reported recovery path if the adaptive step budget is exhausted.
Each swirl contribution uses a compact C2 quintic support falloff, while the center singularity is regularized relative to the swirl radius. These choices keep the combined field smooth across influence boundaries and independent of output resolution.
This is an implementation comparison rather than a strict one-variable A/B: the stock node uses sequential map composition, while the custom node integrates the flow of a superposed velocity field.
Edited by animatrix_ - 2026年8月17日 15:46:42
- animatrix_
- 5319 posts
https://www.patreon.com/animatrix/posts/opencl-intrinsic-168438241 [www.patreon.com]
I've been developing a custom OpenCL point relaxation solver for surface distributions. The input geometry is first triangulated, after which the OpenCL solver operates directly on the resulting surface topology.
Rather than treating the scattered points as a purely Euclidean point set, each point maintains its position on the surface using a primitive and barycentric coordinates. Local neighborhoods are constructed by traversing connected triangles and unfolding the relevant surface region into a local 2D chart.
Within this chart, neighboring points define a Voronoi cell, or a power cell when weighted radii are used. The cell is clipped against the actual unfolded surface patch, and its centroid provides the relaxation target.
The resulting 2D displacement is then converted back into tangent-space motion and walked across the triangle mesh, updating the point’s primitive and barycentric coordinates as it crosses edges.
This allows the relaxation to operate according to the intrinsic connectivity of the surface rather than relying only on straight-line proximity in 3D. Points that are spatially close but separated by a fold do not automatically become neighbors, while points connected through the surface can still interact through the unfolded local patch.
The solver also uses distance-ordered surface traversal and deterministic processing of neighboring samples. The primitive-to-point lookup is assembled in parallel using atomics, so its linked-list insertion order is not inherently deterministic. Relevant constraints are therefore processed in a stable order before the final Voronoi cell is constructed, avoiding result differences caused purely by GPU insertion order.
The relaxation step includes adaptive damping, reversal detection, over-relaxation, and a local step limit. It also tracks a number of quality and convergence conditions, including incomplete surface patches, point and cell capacity limits, nearest-neighbor completeness, overlapping chart regions, boundary interaction, and per-point displacement history.
These diagnostics make it possible to reduce the aggressiveness of a step when the local solution is unreliable rather than blindly accepting the computed centroid.
For comparison, I tested the solver against the Scatter SOP relaxation using the same point distribution. On this particular surface, the custom OpenCL solver reaches a much more uniform distribution in roughly 35 iterations, while Scatter still retains several large under-covered regions after 1,000 iterations. Even at 10,000 iterations, the same gaps remain.
Another difference is convergence behavior. With Scatter, increasing the iteration count from low values through hundreds and eventually thousands continues to change the distribution rather than clearly settling into a stable configuration. The custom solver converges much earlier and produces substantially more even surface coverage.
I'm also developing an intrinsic Delaunay triangulation, or iDT, variant of the solver.
The current implementation traverses the triangulation already present on the mesh. An iDT approach would instead construct connectivity according to the intrinsic surface metric, allowing poorly shaped local triangulation to be replaced by connections that are better suited to intrinsic surface traversal and unfolding.
This is especially interesting for operations such as relaxation, neighborhood search, smoothing, attribute transfer, and other algorithms that depend on local surface connectivity. On a general curved mesh, however, using a virtual intrinsic triangulation also requires a robust mapping between that intrinsic representation and the original embedded surface, so there is more work involved than simply flipping triangle edges.
