Technical Discussion » Modifing Parm with Python
By Mohanpugaz,
- 0
- 145
By Mohanpugaz
Technical Discussion » Solaris - Layout Node with different Variants
By Klonkel,
- 3
- 2197
By kumpa
Technical Discussion » How could I rotate "Copied to Points" geos randomly...?
By Masoud,
- 11
- 48560
By toadstorm
Technical Discussion » Setting Current values as "default value" for all parameters in OTL or digital asset
By Mohanpugaz,
- 4
- 10083
By t3
Technical Discussion » Parameter Expression to return value of a string attribute
By Mohanpugaz,
- 5
- 5868
By Sigil
Houdini Lounge » Attribute Value as Label?
By subscriptions,
- 8
- 5438
By tamte
Technical Discussion » SideFX Labs conflict with Redshift houdini.env, in 19.5.569
By cheesetroyer,
- 7
- 1676
By cheesetroyer
Technical Discussion » How to display local coordinate gnomon of packed prim?
By jerry7,
- 5
- 1514
By tamte
Technical Discussion » Dynamic Parameter Generation for Doors in Houdini
By Davide Ruzzenenti,
- 7
- 1243
Technical Discussion » Adding Objects in Path using Primwrangle
By vpfx,
- 5
- 1004
By vpfx
Houdini Indie and Apprentice » Accessing PDG inputs in Python expression
By jedmitchell,
- 3
- 1515
By Mohanpugaz
PDG/TOPs » PDG - Python list to work items
By Mohanpugaz,
- 4
- 1081
By Mohanpugaz
Technical Discussion » How to change viewport color, disable grid from Python
By AndreasOberg,
- 4
- 1460
By Mohanpugaz
PDG/TOPs » creating multiple mp4 files from flipbooks with ffmpeg top
By Bondar Igor,
- 3
- 4201
By Mohanpugaz
Technical Discussion » PDG Output is missing when Fetching a LOP - [SOLVED]
By Mohanpugaz,
- 1
- 534
By Mohanpugaz
Technical Discussion » How to copy only peripheral polygons?
By Artadecram,
- 3
- 872
By jerry7
Technical Discussion » Vellum Glue - Rotations
By Mohanpugaz,
- 1
- 650
By Benyee
Houdini Indie and Apprentice » Vellum glue constraints rotation free
By mzigaib,
- 5
- 1967
By Mohanpugaz
Technical Discussion » Remesh 2.0 - possible bug?
By Mohanpugaz,
- 2
- 773
By Mohanpugaz
Technical Discussion » Problem with random scale of cubes using attrandomize
By proceduralist,
- 2
- 844
By proceduralist
