Hi everyone,
I do have a problem on H12.
I want to edit a attribcreate parameter interface with adding spare float and interger value. When adding those parameters when hitting apply or accept a “#” at the back of my paramter Name and while opening again the edit parameter interface it's impossible to edit those new parameters.
And the parameters doesn't appear inside the parameters of the node.
Do anyone have an idea on this problem?!
Edit Paramter interface problem
3495 4 2- fido972
- 30 posts
- old_school
- 2540 posts
- symek
- 1390 posts
- fido972
- 30 posts
Thanks guys for taking time to give me an help.
yes this was the problem. The things it's exactly the same thing i've done on H11 and there was not this problem. So thank you a lot.
SYmek
Looks like you're trying to drop a spare parameter into multi-parm folder, which you're not supposed to modify. You can add spare parm bofore multi-parm block.
- grayOlorin
- 1799 posts
