Hello, I had a working Houdini Apprentice installed until I launched it after installing Python 2.7(from python website). Houdini doesn't launch and the message below keeps printing in Houdini Console.
I have 0 idea on how to fix this. Should I install Python 3.3? Is there an order of installation I must do? Please help me.
File “C:\PYTHON27\LIB\abc.py”, line 109, in register
if issubclass(subclass, cls):
File “C:\PYTHON27\LIB\abc.py”, line 184, in __subclasscheck__
cls._abc_negative_cache.add(subclass)
File “C:\PYTHON27\LIB\_weakrefset.py”, line 84, in add
self.data.add(ref(item, self._remove))
TypeError: cannot create weak reference to ‘classobj’ object
Could not create the default HDA shelf tool for ‘cop2net’:
File “<stdin>”, line 1, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.683/houdini/python2.6libs\hou.py”, line 36122, in <module>
import os
File “C:\PYTHON27\LIB\os.py”, line 398, in <module>
import UserDict
File “C:\PYTHON27\LIB\UserDict.py”, line 84, in <module>
_abcoll.MutableMapping.register(IterableUserDict)
Could not create the default HDA shelf tool for ‘opengl’:
import os
import UserDict
Could not create the default HDA shelf tool for ‘framedep’:
import os
import UserDict
Could not create the default HDA shelf tool for ‘batch’:
import os
import UserDict
Could not create the default HDA shelf tool for ‘dopnet’:
import os
import UserDict
Could not create the default HDA shelf tool for ‘geometry’:
import os
import UserDict
Houdini and Python 2.7
11846 8 1- icerust
- 68 posts
- pbowmar
- 7025 posts
- Cyzor
- 181 posts
Good idea. The Houdini system requirements still read as though Python 2.6.4 is the latest supported version.
Maybe Houdini can't find the new Python library and executable paths. Updating the environmental variables to point to the latest Python location might help in that case.
Nevertheless, on Windows, the application ought to default to the Python version packaged with Houdini, residing in the standard $HFS location.
http//www.sidefx.com/docs/houdini12.1/hom/
- icerust
- 68 posts
- graham
- 1908 posts
- Rudra
- 4 posts
Hey guys. I have spent the whole day trying to understand what's wrong with my PyQt4<->Houdini setup and why Houdini(12.5.456) doesn't see PyQt4 libraries.
Currently python-2.7.5 from brew is on my mac(Mountain Lion) and Houdini uses 2.6.7. PyQt works perfectly while I launch any script from terminal but Houdini doesn't see libraries.
>>> import PyQt4
File “<console>”, line 1, in <module>
ImportError: No module named PyQt4
Please advice what should I do to make PyQt visible to Houdini?
>>> import PyQt4
- graham
- 1908 posts
- Dmitriy Nasyrov
- 5 posts
Still no luck. I installed Python 2.6.8 + PyQt4. Surely it works in terminal, also it works if I add HOUDINI_PYTHON_BIN = /opt/local/bin/python to houdini.env. And python can load PyQt4 now. But there are a bunch of errors in Houdini appears with this changes:
File “/Library/Frameworks/Houdini.framework/Versions/12.5.456/Resources/houdini/python2.6libs/sas/localassets.py”, line 10, in <module>
import urllib2
File “/opt/local/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py”, line 94, in <module>
import httplib
File “/opt/local/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py”, line 78, in <module>
import mimetools
File “/opt/local/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/mimetools.py”, line 6, in <module>
import tempfile
File “/opt/local/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/tempfile.py”, line 34, in <module>
from random import Random as _Random
File “/opt/local/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/random.py”, line 47, in <module>
from os import urandom as _urandom
ImportError: cannot import name urandom
I found HOUDINI_PYTHON_LIB, HOUDINI_USE_HFS_PYTHON, HOUDINI_PYTHON_VERSION variables and tried them with different values, but that doesn't help.
Any suggestions?
import urllib2
import httplib
import mimetools
import tempfile
Any suggestions?
- Dmitriy Nasyrov
- 5 posts
Actually if I set python lib to:
HOUDINI_PYTHON_LIB = /opt/local/Library/Frameworks/Python.framework/Versions/2.6/Python
similar to rvinluan's advice from this thread:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=28933&highlight=HOUDINI_PYTHON_BIN [sidefx.com]
and HOUDINI_PYTHON_VERSION to 2.6 then Houdini doesn't want to start at all
