Long Time Maya User trying to learn Houdini
3167 4 0- tadian
- 90 posts
First off, everything I see that Houdini can do is pretty amazing. Coming from a maya workflow things are different. I'm trying to follow some beginner tutorials to get the hang of things. Problem I'm currently having is with the drag select. I go into wire shade, selection mode and then I can't drag select multiple points. I can individually pick them and grow the selection. But can't drag select the multiple points. Not sure what I'm missing. THoughts?
- Lewul
- 250 posts
- Lewul
- 250 posts
- edward
- 7727 posts
- zarti
- 330 posts
hi and welcome ,
if so , you can keep pressed the Select Tool button and select the Brush Picking mode instead of Box Picking .
i just tried and was able to select in both modes on build H12.5.316.22 .
.cheers
I go into wire shade, selection mode and then I can't drag select multiple points. I can individually pick them and grow the selection. But can't drag select the multiple points. Not sure what I'm missing. THoughts?i suspect , from what im reading , that you are trying to paint the selection ..
.cheers
