Can you / has anyone layered multiple captures?
4066 16 1- phrenzy84
- 249 posts
I have been trying this for a while and have not been able to layer multiple captures.
I would have one bone chain capture and deform geometry , then after the deform want to do another set of captures and deforms.
Is this allowed because it simply isn't working.
I am deleting all weights after the first capture/deform and have gone through every option but it seems to makes no difference.
Has anyone done this before?
-andrew
-andrew
- pbowmar
- 7025 posts
- phrenzy84
- 249 posts
Yea i can't seems to get capture > paint > deform and then another set of capture > paint > deform
These are with two separate bone chains.
I've made sure that all weights are deleted after the first deform but it seem to take. I've tried specifying the hierarchy and then bones…. all sorts. The first capture works but the second one doesn't.
- pbowmar
- 7025 posts
- phrenzy84
- 249 posts
- pbowmar
- 7025 posts
- pbowmar
- 7025 posts
- phrenzy84
- 249 posts
I have no idea what i was doing wrong. I thought maybe because you were using a capture proximity instead of a regular capture sop there was something different.
So i made it with just a regular capture. Works. :shock:
The reason i am asking this is i want to have a sticky object influences by one deform, and that sticky object be the root for another bone.
I've set it up here with no success. I thought maybe the sticky had to be fetched but nope.
- 8583 posts
phrenzy84
that kind of setup will definitely work
I was using it in the past for controllers which were sticking on deforming geometry as a secondary layer of control on top of shape animation
you will need to update capture pose to sticky location so that there is no double deformation or missed capture
so simply reference it in bone's Capture Bone Translate&Rotate parameters using origin() expression
- phrenzy84
- 249 posts
tamte
Yep that is exactly what i am looking for.
Thanks for the tip. I will post a example if/when i get it working.
edit/ though i am slightly puzzled, if i will be painting the capture then why do need to make sure the region is in the right place if in the end it will all be custom. Anyways, i will try it out.
- phrenzy84
- 249 posts
- 8583 posts
you can include static bone or (another compensated bone) additionally to all your sticker bones
then assign all the points to that bone
and then paint influence of your stickers (so the smoothing will work because it can now blend between bone weights)
or even better
capture with that one bone, set weight to 1
make another capture with all the stickers
uncheck Destroy Existing Weights on that capture
play with Blend Factor so they will nicely blend in based on their capture region so they update their capture weights when you correct your sticker locations
or even better
- 8583 posts
phrenzy84tamte
…edit/ though i am slightly puzzled, if i will be painting the capture then why do need to make sure the region is in the right place if in the end it will all be custom. Anyways, i will try it out.
if you will paint the weights anyways and not use capture regions to capture on the fly then deformation will work even when not making sure capture regions are in corect place
however
referencing world location has another reason
it compensates for bone movement that is caused by deforming surface, the bone is stick onto
therefore avoiding double deformation you would have even if your weights would be painted
- 8583 posts
here is the working example of sticky bone acting as a second(or whichever) deformation layer with pose compensation for underlying deformation
as I noticed that origin() seems to be using XYZ rot order to compute rotations and capture pose seems to be using ZYX (even if bone rot order is set to XYZ) I used Object CHOP to compute correct Capture Pose
- edward
- 7726 posts
tamte
origin() and friends use a fixed SRT, XYZ transform order due to legacy. I think this was rectified with the equivalent Python functions which allow specifying the transform order. However, I'm not sure the speed of doing this compared to an Object CHOP.
- 8583 posts
thanks edward
yes, Python and
hou.node(“../sticky1”).worldTransform().extractRotates(“srt”, “zyx”)
gives correct values as well
yes, Python and
- phrenzy84
- 249 posts
