When you try to open a certificate error takes off
Qt Warn: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
Error running Python code to access the help manager:
File “<stdin>”, line 1, in <module>
File “/opt/hfs15.0.244.16/houdini/python2.7libs/houdinihelp/__init__.py”, line 458, in startHelpServer
from paste.httpserver import serve # @UnresolvedImport
File “/opt/hfs15.0.244.16/python/lib/python2.7/site-packages/paste/httpserver.py”, line 317, in <module>
from OpenSSL import SSL, tsafe
File “/usr/lib/python2.7/dist-packages/OpenSSL/__init__.py”, line 8, in <module>
from OpenSSL import rand, crypto, SSL
File “/usr/lib/python2.7/dist-packages/OpenSSL/rand.py”, line 11, in <module>
from OpenSSL._util import (
File “/usr/lib/python2.7/dist-packages/OpenSSL/_util.py”, line 4, in <module>
binding = Binding()
File “/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py”, line 89, in __init__
self._ensure_ffi_initialized()
File “/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py”, line 113, in _ensure_ffi_initialized
libraries=libraries,
File “/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/utils.py”, line 80, in build_ffi
extra_link_args=extra_link_args,
File “/usr/lib/python2.7/dist-packages/cffi/api.py”, line 340, in verify
lib = self.verifier.load_library()
File “/usr/lib/python2.7/dist-packages/cffi/verifier.py”, line 75, in load_library
return self._load_library()
File “/usr/lib/python2.7/dist-packages/cffi/verifier.py”, line 151, in _load_library
return self._vengine.load_library()
File “/usr/lib/python2.7/dist-packages/cffi/vengine_cpy.py”, line 149, in load_library
raise ffiplatform.VerificationError(error)
VerificationError: importing ‘/usr/lib/python2.7/dist-packages/cryptography/_Cryptography_cffi_36a40ff0x2bad1bae.x86_64-linux-gnu.so’: /usr/lib/python2.7/dist-packages/cryptography/_Cryptography_cffi_36a40ff0x2bad1bae.x86_64-linux-gnu.so: symbol EC_GFp_nistp521_method, version OPENSSL_1.0.1 not defined in file libcrypto.so.1.0.0 with link time reference
OS: debian wheezy 8.2
I tried to update the library libssl1.0.0, but it did not help.
How can fix this issue?
H15: Help Contents
4536 4 1- alexwheezy
- 201 posts
- awong
- 818 posts
- OneBigTree
- 378 posts
- awong
- 818 posts
- alexwheezy
- 201 posts
