I recently simulated whitewater for my fluid sim. The fluid sim loads fine, but for some reason the whitewater sim gets an “unable to read file” error in the whitewater_import node, when I go into the node I can trace the error back to the “Read_back” Node which says it's unable to read the file. I even put the sim into another folder Dhome/Whitewater.$F.bgeo
It still doesn't work
I hope someone can help me, I've been trying to render this thing for a month now.
Thanks in advance.
Houdini unable to read .bgeo file simulation
11274 10 1- Yehbe
- 47 posts
- Enivob
- 2539 posts
The first thing that comes to mind is maybe the zero-padding is off? You do see your whitewater files in the folder, right? Does the filename have any padded zero like my_sim_00123.bgeo instead of my_sim123.bgeo? If so you can adjust that by counting the number of digits and appending the $F with that count, for instance Dhome/Whitewater.$F4.bgeo
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Yehbe
- 47 posts
- awong
- 818 posts
- Yehbe
- 47 posts
- awong
- 818 posts
- Yehbe
- 47 posts
- Yehbe
- 47 posts
Don't know if this is relevant, but when I only had about 25 frames cached, I could just render the whitewater with no problems. I just cached the rest and now it's unable to read. Also when I have to select a cache in the node, it doesn't show a .sim extension as a compatible extension.
Windows 7| 24 GB RAM DDR3| AMD Athlon X4 760K Quad Core Processor 3,8 Ghz | Nvidia GTX 970 4GB
- awong
- 818 posts
So you're using the whitewater_sim/output node to cache the simulation? If that's the case, then those files are actually .sim files. If that's the case, then you could load those files by using the “Playback Simulation” parameter at the top of the whitewater_sim.
Alternatively, if you want to cache only the geometry (i.e. bgeo), you could use the DOP I/O SOP. The shelf should have created this node at whitewater_import/import_whitewater. You can use it to save and load geometries.
Andrew / アンドリュー
- Yehbe
- 47 posts
So it automatically loaded another simulation that's like in the $HIP directory. I loaded the .bgeo anyway and it's working somehow. But I'm wondering if the new simulation is being loaded or the old one. Because there's quite a difference between the two.
Thanks alot, you've really helped me, I just need to know that one thing, then I'll have closure.
- awong
- 818 posts
