I am working through the Mantra Surface Shader (after unlocking it). Does anyone know where a texture map related to the parameter Surface->Diffuse Map connects to within the interior of the Mantra Surface Shader? I checked dependencies of the Map parameter and it points to something called diff_colorTexture but I can't find it in any of the Mantra Surface Shader interior nodes.
VR
Lars
2072 4 1- LARSX
- 148 posts
- bonsak
- 459 posts
- goldfarb
- 3455 posts
on the surfacecolor called “diffColor there is a parameter called diff_ olor_Texture
it's been promoted and has a little nub poking out of it - double click the nub and the node will fly out
on the parameters of the mantra surface there is an option to ”use map"
this will make the file path available
see pic
HTH
see pic
HTH
- LARSX
- 148 posts
Thanks! I had looked at that parameter but did not double click its knob to expand it. I know how to plug a map in but wanted to trace how this works in the Mantra shader network. I also see now I could have hovered over the Map parameter to see what the parameter name was.
VR
Lars
VR
Lars
Lars Wood
Future Vision Guide
Advanced Research And Development
Future Vision Guide
- LARSX
- 148 posts
