Convert Point Group into a Curve?
4915 3 1- Shawne Martin
- 16 posts
- Enivob
- 2539 posts
When I have a selection that I want to isolate for a further purpose I will click on the Delete icon in the tool shelf. This will drop down a Blast node with a series of numbers in the group. Those numbers are your selection.
What I do is select all those numbers, CTRL-A and copy them to the clip board. Delete the Blast node. Then I drop down a Delete node and paste those numbers into the group field of the Delete. The Delete node has the option to delete the numbers in the group or the inverse which is called non-selected.
After deleting the non-selected you now have your selection as a branch that you can further process. You could then drop down a Convert node and which can convert from various types to various types.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- grayOlorin
- 1799 posts
- animatrix_
- 4523 posts
You can also use this tool:
https://www.orbolt.com/asset/animatrix::polyCurvesFromEdges::1.00 [orbolt.com]
