Hi ppl,
I am new to Houdini and have run into some weird issue but cant figure out what I am doing wrong. Please see the attached image.
Any help would be appreciated.
SubDivide giving weird issue with PolyBevel
2412 7 0-
- Juned
- 15 posts
- Juned
- 15 posts
- anon_user_89151269
- 1755 posts
- Juned
- 15 posts
- BabaJ
- 2048 posts
I opened your file…I agree with you that the result you get is not what is expected.
However, with Houdini we have the capacity to do many different things in different ways for different purposes.
I looked at your file in wireframe mode and was ‘puzzled’ by why when the node is doing the subdividing it wasn't going to the ‘nearest’ points to each other - which is why you are getting the current results.
So I thought, well why would the algorithm work that way?…So then I looked at the paramaters for the subdivide node and sure enough there is a drop down menu for algorithm.
Changing that paramater to ‘OpenSubdiv Bilenear’ option gives us the ‘expected’ result…or better put ‘desired’ result.
There is likely situations where the desired result requires a different algorithm…but I'm still very much a Novice and wouldn't know, another example of the ‘depth’ of Houdini.
- Juned
- 15 posts
- goldfarb
- 3456 posts
- Juned
- 15 posts
