I created a variable in a Python Sop called StartingPoint.
How can I use this variable in parameters in Sops down the pipe.
So I got to a Sop parameter, switch it to Python and type in what??
Done a lot of research online but found only info about doing calculations etc… Nothing about putting a variable you've created.
Python Variable
1491 2 0- firefly9000
- 169 posts
- Enivob
- 2539 posts
The Python SOP is really just a one-shot code snippet that falls out of scope once it executes. So there is no way to to preserve a “global” variable. AFAIK. But you can use python to write a value to the detail attribute of the current geometry. This would be a likely place to store global variables for later processing down stream.
Check out the docs for more info.
http://www.sidefx.com/docs/houdini15.5/hom/hou/Attrib [sidefx.com]
n = geo.addAttrib(hou.attribType.Global, "my_global", 100)
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- BabaJ
- 2042 posts
When I want self-created Python variables that I am going to use in different paramters I use the “Python Source Editor” which is under the Windows tab at the very top.
It can be as simple as wanting it to be like a “global constant” such as “myvalue = 34” in which to use in any paramater or python expression elsewhere it's a simple matter of using “hou.session.myvalue”
I also sometimes define functions there in the python editor and reference it the same way like hou.session.myfunction().
Sometimes for various reasons I'll even put a channel reference in the pyton source editor like; my_reference = ch(“obj/node/theparamter”) and just use that; hou.session.my_reference
