I am trying to render a large scene, but Mantra is crashing after approx 10 frames reporting a Command Exit Code 255.
It's frustrating to restart the render over and over again.
Can somebody explain to me what Command Exit Code 255 is, and give me some advice how to prevent Mantra from crashing?
Houdini Indi 15.0.416
Dell Precision T7910
2x Xeon 2.4GHz
64 GB Ram
Windows 7 64 bit servicepack 1
Nvidia Quadro K4200 / Driver 9.18.13.4066
Command exit code 255
4387 6 0- Reco
- 14 posts
- circusmonkey
- 2624 posts
- Reco
- 14 posts
Thank you for your answer circusmonkey.
Sorry, but I can't post the scene. It is heavy with lots of objects and textures.
The render time for one frame i approx 1.5 hour.
On the other hand, I can give you a bit more information.
Please see the text below as well as the attached jpg image.
Problem signature:
Problem Event Name: APPCRASH
Application Name: mantra.exe
Application Version: 15.0.0.416
Application Timestamp: 56e79cee
Fault Module Name: libVGEO.dll
Fault Module Version: 15.0.0.416
Fault Module Timestamp: 56e7a37c
Exception Code: c0000005
Exception Offset: 00000000000d26f4
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: ce1a
Additional Information 2: ce1a63d5de8f20cbd7c96b545194a3cb
Additional Information 3: 7db5
Additional Information 4: 7db5d9b0c4ab99f89ff6a7cfc9157218
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 [go.microsoft.com]
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Problem signature:
Locale ID: 1033
- circusmonkey
- 2624 posts
- Reco
- 14 posts
Thank you again circusmonkey.
I just don't know were to start. Simplified scene? Do you mean reduce polygons in all the objects? Reducing number of objects? No texture? One object at the time? or one light at the time.
Sorry, but I have no clue how I can simplify it.
I hoped that the 255 code would more or less point in one direction. Or at least limit the problem into one area.
- edward
- 7722 posts
- Reco
- 14 posts
Just an update. The problem seems to be solved. Command Exit Code 255 is a network issue and not a Houdini specific problem.
The project was stored on a server. Was open on a workstation from the server. The rendered frames was saved back to the server.
I moved the project over to the workstation, and no more Command Exit Code 255.
