"Waterfall Flip Fluids Webinar Tutorial"
14299 34 4- Sneil
- 72 posts
Following this tutorial for whitewater, however he uses a VOP SOP @ 30:30 into the tutorial (https://www.youtube.com/watch?v=l2u-DXOxouY) [youtube.com] for separating particles that have a change in velocity. What do I need to use as a replacement to do this? Still a beginner here so if someone could break it down a bit I'd really appreciate it. Thanks very much.
Neil
Neil
Edited by Sneil - Feb. 13, 2017 11:45:35
- JasonSlab
- 1533 posts
- Sneil
- 72 posts
- Sneil
- 72 posts
I just came back to this after being away for a bit, but I'm again having issues with this tutorial when he comes to creating the spray sim DOPNetwork at 44:10 and having the separated particles created become emitters. I don't get the same results with Houdini 15 as things have obviously changed when creating the POP object and POP solver. Where exactly do I go from here to get things working? At a loss…
Again, appreciate any and all help.
Edited by Sneil - Feb. 9, 2017 08:22:47
- Sneil
- 72 posts
- A-OC
- 253 posts
- Sneil
- 72 posts
- Sneil
- 72 posts
- A-OC
- 253 posts
- Sneil
- 72 posts
Here is the file. I reloaded a previous save and tried reapplying the whitewater, and I now receive a “No fluid object selected for whitewater” error. So I can not get the whitewater to work at all now in the scene when I try to apply it to my flipfluidobject in the DOP network.
Also, at some point the FPS in my scene started to drop heavily. I had figured it was due to my older machine and the geometry starting to really add up. However, after deleting nearly everything from the scene to give a simple file, my frames are still drastically low, which it wasn't like at all before the scene started getting more complex. Not sure what is going on but it is this way for me in the file I'm uploading when they used to be butter smooth.
Another issue is the geometry on my main cliff object needs some serious cleaning up after the poly extrusion. Might just have to start another thread on how to go about doing that though… I'm not sure if most are expected to have a lot of previous modelling experience before jumping into Houdini, but mine is quite limited so I'm still learning modelling techniques along with learning Houdini at the same time. Anywho… really appreciate the help A-OC.
Edited by Sneil - Feb. 10, 2017 21:49:03
- A-OC
- 253 posts
I couldn't check your file properly because you forgot to lock the file sop inside the cliff geometry.
But you had the Flip Object hidden flag on, that might have been a problem.
I added the white water and everything works as expected.
I do it like this: Select the Flip Object and Flip Solver nodes, then click the shelf button.
- Sneil
- 72 posts
Alright, got the whitewater to work again however, my fluid sim has reverted to spheres again. Here's an updated file with the Geometry file node locked. Also, is this whitewater more of a fog then rather small geometric particles? Seems to have an odd look to it. Cant find anything on the web regarding working with the whitewater shelf tool and all of it's features.
http://www.filedropper.com/whitewaterbasicscene2 [filedropper.com]
Edited by Sneil - Feb. 11, 2017 10:02:29
- Sneil
- 72 posts
OK, Making a bit of progress. The big spray at the waterfall looks a bit goofy, but at least I'm getting somewhere now. Thanks again A-OC, I owe ya one!
Edited by Sneil - Feb. 11, 2017 18:43:33
- Sneil
- 72 posts
OK after playing around with it this seems to be the best result I am able to get, which is somewhat unsatisfactory. How do I get the results from this image which was done in Houdini? https://i.vimeocdn.com/video/496148453.jpg?mw=1920&mh=1080&q=70 [i.vimeocdn.com] The foam looks much better having spectacularity and actually floats on the surface of the fluid itself.
((Ignore the texture on the base of the model below which hasn't been UV mapped yet.))
Edited by Sneil - Feb. 13, 2017 14:03:34
- A-OC
- 253 posts
The way I do it is very slow when rendering but it gives me the most satisfactory results as of now.
Render as small points, around 1 mm in radius, with a water-like reflection, no refraction, opacity around 0.15, faux caustics. Maybe add a little diffuse.
I'd be very glad to hear a faster approach.
*edit. Actually add a lot of diffuse, now that I'm checking.
Edited by A-OC - Feb. 13, 2017 18:32:16
- A-OC
- 253 posts
- Sneil
- 72 posts
- A-OC
- 253 posts
- A-OC
- 253 posts
- Sneil
- 72 posts
