OK, so I'm trying to replicate some of the functionality of X-Particles in C4D and I found this: https://www.sidefx.com/docs/houdini15.5/particles/react [sidefx.com]
Which talks about the Creep on the Drive Particles shelf.
However, I can't find it anywhere.
I found a Drive Simulation shelf, but no ‘Creep’ in there.
I'm trying to replicate shooting particles from an emitter at an object and having those particles flow ‘over’ the object.
This is what I'm after: https://vimeo.com/101104677 [vimeo.com]
Thanks,
Jim
What happened to the Drive Particles shelf?
1911 3 1- reelinspirations
- 177 posts
- Enivob
- 2538 posts
There are quite a few examples on OdForce demonstrating this technique. Here are a few HIP file I found by searching for “particle creep”.
http://forums.odforce.net/topic/26638-rbd-orientation/?do=findComment&comment=153939 [forums.odforce.net]
http://forums.odforce.net/topic/26752-pops-following-animated-mesh/?do=findComment&comment=154565 [forums.odforce.net]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Simon Russell
- 164 posts
Not sure if I'm duplicating what Enivob posted but Matt has a nice technique here: http://www.tokeru.com/cgwiki/index.php?title=HoudiniDops#Pop_stick_to_surface [tokeru.com]
The only thing to look for is the inputs on the pop wrangle, easy to miss.
Being a technical ninja I can't work out how to attach a file to this post so here's a dropbox one: https://www.dropbox.com/s/ukc2jc1l4blngl1/Tree.hiplc?dl=0 [dropbox.com]
Edited by Simon Russell - Feb. 21, 2017 11:43:42
- reelinspirations
- 177 posts
