I have a pop network with a simple sprite and colour nodes. When I try to render my image all I get is grey planes - not with no transparency or shading. I looked at a previous post about how to change the colour - using an attribute SOP with Cd to Diff. However this removed the sprites from my render, even though they are in my viewport. Could some one tell me how to fix the sprite problem and how to get the transparency to render.
Cheers.
Rendering sprites
5605 8 1- Dave Bate
- 14 posts
- edward
- 7754 posts
- goldfarb
- 3456 posts
there are a few video tutorials that show how to do this:
here : http://sidefx.vislab.usyd.edu.au/houdini_video/by_topic/effects/index.html [sidefx.vislab.usyd.edu.au]
the two in the Sprite Stamping section
at 3dbuzz : in the Video Tutorial section > Houdini VTM issue #4
12 Basic Sprite Rendering
13 Developing a Sprite Shader with VOPs
HTH
HTH
- Dave Bate
- 14 posts
I have looked at these videos and I cannot see what I am doing wrong, perhaps I am just missing something. If someone could check my file just to see if I am doing something silly. Cheers.
http://people.pwf.cam.ac.uk/db410/sprite_problems.hipnc [people.pwf.cam.ac.uk]
- edward
- 7754 posts
- Dave Bate
- 14 posts
I have got the sprites to render as circles by following the 3DBuzz vid, but the particles will not render with the correct colour (from the Color Pop). pops are not covered in the vid. Any help with this? - it is displaying correctly in the viewport and the attribute sop trick from before will not work with sprites.
- edward
- 7754 posts
- Dave Bate
- 14 posts
- edward
- 7754 posts
