Back lit single sided geo SSS with principled shader
1957 3 0- Simon van de Lagemaat2
- 116 posts
- 7803 posts
You can, but it's broken, you can make it work with:
then add the render property:
vm_smoothP “Fix Shadow Terminator”
and disable it.
vector diff_color,trans_color; bsdf f; vector nn,ni,tng; diff_color = set(0.1,0.35,0.001); trans_color = set(0.05,0.15,0.0001); nn = normalize(N); ni = normalize(I); nn = frontface(nn,ni); tng = select(dot(nn,Ng),Ng,-Ng); f = 2.0 * ( diff_color * diffuse(nn,tng,"label","diffuse") + trans_color * translucent(-nn,-tng,"label","refract") );
and disable it.
- 8594 posts
- 116 posts
tamte
you should be able to just use PBR Diffuse VOP with inverted normal, you can name the component “refract” or maybe “sss” if you want
and just layer that with your mat
Thanks! both of you! I also forgot about the translucency refract model in the classic shader. It would be nice if the principled shader supported translucency. This is one of its blind spots.
owner the Embassy VFX
