Move multiple 'copied' objects along a spline
   8507   13   4
I have a spline that I've copied a bunch of spheres to, but I want to ‘move’ the sphere's along the spline.
I know how to set up a single object to follow a spline, but have no clue how to make this work.
For those who know Cinema 4D, what I'm trying to do is ‘clone’ a bunch of objects to a spline, then use the ‘offset’ to animate them along the spline.
Jim
move_along_spline.hiplc (62.3 KB)
Reel Inpsirations
Houdini Work in Progress [vimeo.com]
Hi Jim,
is something like this right?
P.S. The parm that does the moving is the ‘Offset’ in the wrangle SOP
Edited by friedasparagus - May 25, 2017 15:08:39
move_along_spline_try.hiplc (73.9 KB)
Henry Dean
Wow, thanks so much!
That is exactly what I needed. Houdini rocks, if you know what you're doing LOL!
Edited by reelinspirations - May 25, 2017 15:26:54
Reel Inpsirations
That is pretty awesome but I don't really understand how you did it. Is there a tutorial out there that would cover something like this. I am also from C4D so I'm not sure how this works in Houdini.
Hi friedasparagus, thanks for your example. I was looking for something like this.
I have a next question you or someone else can maybe help me with: would it be possible to introduce a randomness to the amount each point is offset?
Thanks,
Jasper
you can use a same @curveu attrb and randomize that and if you want more control use a fit function.
same but different, using the attribute interpolate sop, plus a slider for randomness.
move_along_spline_attribinterpolate.hiplc (83.6 KB)
Thanks both, works like a charm!
- Jasper
mestela
If I take this example and use copy to points to have many splines, Attribute Interpolate brings all objects to 1 spline even though I have many copies. How can duplicate it, keep the points and position of the splines?
Edited by plazadelmar - Dec. 12, 2018 10:00:11
move_along_spline_attribinterpolateCOPY.hipnc (92.2 KB)
line 9 in your animate_curveu_add_random
change:
@sourceprim = 0;
to
@sourceprim = @primnum;
or
i@sourceprim = @primnum;
to be explicit
CG Supervisor
Framestore, NY
tamte
change:
@sourceprim = 0;
to
or
to be explicit
Amazing, it works. Thanks.
Edited by plazadelmar - Dec. 12, 2018 14:19:52
One more noob question. If I would like to each spline to produce random speed for the spheres I could probably solve it with forEach. Unfortunately, I have not been able to create this effect. How could I solve it?
Edited by plazadelmar - Dec. 12, 2018 14:22:39
plazadelmar
line 3, change
t = @Time * ch('speed');
to
t = @Time * ch('speed') * fit01(rand(@primnum), .5, 1);
which will multiply the speed of each sphere by random number between 0.5 and 1 per curve
Edited by tamte - Dec. 12, 2018 14:33:09
CG Supervisor
Framestore, NY
tamte
plazadelmar
line 3, change
to
Awesome. Thank you
Edited by plazadelmar - Dec. 18, 2018 12:55:10
