I am using Houdini 16.0.671 QT4 on a brand new macbook pro 2017 (specs below) and every time I try to render something, Houdini is generating the scene forever. Even the simplest of renders takes a very long time.
Rendering a simple primitive sphere with a default principled shader material with the color tweaked took
an astonishing 22 seconds to generate. 22 seconds to generate and approx. 3 seconds to render.
The computer should be more than enough to render a simple sphere faster than that.
If i pause the render and do changes, it does not have to generate the scene but at the cost of computer speed.
Does anyone know why this is happening or have run into same problem?
Submitting a small hip with the primitive sphere example state above.
//Simon
MacBook Pro (15-inch, 2017)
macOS Sierra 10.12.5 (16F2073)
2,9 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Radeon Pro 560 4096 MB
Intel HD Graphics 630 1536 MB
RENDERING. MacBook Pro 2017. Generating scene takes forever...
8160 11 2- simonsimon
- 11 posts
- simonsimon
- 11 posts
- 7794 posts
- simonsimon
- 11 posts
- goldleaf
- 4170 posts
- simonsimon
- 11 posts
- goldleaf
- 4170 posts
No problem, sorry I wasn't clearer; yeah, replace
I also noticed on another thread [www.sidefx.com], some Mac-suggested environment variables for better performance. One that might be applicable here, is add this to your houdini.env [www.sidefx.com]:
On a Mac, it's
mantra
with mantra -e none
.I also noticed on another thread [www.sidefx.com], some Mac-suggested environment variables for better performance. One that might be applicable here, is add this to your houdini.env [www.sidefx.com]:
HOUDINI_DISABLE_SOHO_SPOOLING = 1
On a Mac, it's
~/Library/Preferences/houdini/X.X/houdini.env
, where X.X would be 16.0 in this case.
I'm o.d.d.
- simonsimon
- 11 posts
- goldleaf
- 4170 posts
Don't give up, the MacBook Pros are a bit of a hassle with Houdini, it's not just you!
You might need to create the file if it doesn't exist, maybe that's why it's not showing up in the search.
Can you find your Houdini preferences folder? It's
After confirming you can find the folder, open TextEdit, make sure you are inPlain Text Mode through the menuFormat > Make Plain Text, then Save As… and save it to
I'm going off memory a bit, as my Mac died a while back, and I haven't had the chance to replace it yet…
~/Library/Preferences/houdini/16.0
(in case Unix shells are new to you that ~ is your $HOME directory. After confirming you can find the folder, open TextEdit, make sure you are inPlain Text Mode through the menuFormat > Make Plain Text, then Save As… and save it to
~/Library/Preferences/houdini/16.0/houdini.env
. Now that the file exists, paste that environment variable in there, save, and try launching Houdini again.I'm going off memory a bit, as my Mac died a while back, and I haven't had the chance to replace it yet…
I'm o.d.d.
- simonsimon
- 11 posts
- riptor_vfx
- anon_user_37409885
- 4189 posts
aliadel
Anyone would recommend the new Apple MacBook Pro 15" (2017) for 3D work?
It's limited to 16GB ram, so no. MacOS OpenGL/CPU OCL and QT 4/5 is also not very good or doesn't work but you should be able to run Linux/Windows on the hardware, which would improve it's value significantly.
Edited by anon_user_37409885 - Aug. 30, 2017 14:46:49
